03-24-2008 12:47 PM - edited 03-15-2019 09:36 AM
I have a router in H.323 mode, with SRST configured. I am using B-ACD 2.1.2.2. I changed many IOS versions but the result is the same:the script is running until the moment when it must play the audio prompts. I can see "TCL AA: ++ Playing Welcome Prompt and options menu ++" in debug, I can see the file name chosen by script is correct, but I can't hear anything on PSTN phone. I attached debug, config, sh diag and sh flash.
Any help will be highly appreciated.
Thank you,
Cristian
03-28-2008 12:19 PM
When a call comes from PSTN , you need to configure these commands in the CME.
Try :
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
03-28-2008 03:24 PM
Note for the casual reader, the information given above by smalkeric, is incorrect.
03-30-2008 08:48 AM
I resolved this case with TAC.
You can find more information at:
Best wishes,
Cristian
07-28-2013 11:46 AM
Hi, could you send me this problem information, because your link doesn't no longer working.
Tomasz Hinz
