B-acd call anwsering window
Hi all,
I have a B-acd configured and my agents anwser calls from 7am to 19pm. i would like to play a diferent message saiyng something like, Sory, we just work from 7am to 19pm when customers call out of this time window.
Is it possible with B-acd? or any way do with CME ?
thx
Rafael2gc
Hall of Fame Super Gold
Re: B-acd call anwsering window
Hola Rafael,
I guess you're lucky, or that is your X-mas present, but I wrote a modification to B-ACD/AA that does exactly what you want:
http://pbevila.fastmail.fm/public/app-b-acd-aa-2.1.2.2-pl2.tcl
The instructions are in the file itself.
However, there is also an alternative with standard B-ACD/AA: configure as vmail or final number, to another script that simply plays an announcement and then disconnects:
http://pbevila.fastmail.fm/public/disconnect.tcl
This way, once all agents are logged out of the ephone-hunt, you will have the same behavior. The advantage is that this is not time based but it follow the "natural" presence of agents, that is they can extend working hours if they want to.
Hi Paolo,
Thanks for your reply. I've tried the disconnect.tcl but it does not worked.
I'm using service aa flash:app-b-acd-aa-2.1.2.2.tcl
and i changed the vm parameter to
param voice-mail disconnect.tcl
I tested with my four agents in dnd, i head the welcome message, then the message saying all agents are busy and the the message saying that we are unable to take your call.....
I've restarted the router and still not working.
I want my X-mas gift :)
Hola,
If you want the message about office hours to be the only thing announced, please use the modified script "PL2" with the schedule parameters.
Else, you need voice-mail param to be a number.
This number, you configure as looback DP:
dial-peer voice 100 voip
service disconnect
destination-pattern 555
incoming called-number 555
session target ipv4:
This way however, you will have the "all agents busy" message before the disconnect one, that is not much different from what you have now.
Forgot to mention some commands needed for proper service and DP configuration:
application
service disconnect flash:/ivr/disconnect.tcl
paramspace english language en
paramspace english index 0
paramspace english location flash:/ivr/
codec g711u
no vad
I try to use the disconnect.tcl but it works only in certain case.
Other case I hear no message or busy tone so I try to debug the router and I see this error:
Jul 4 13:02:10.199: //77523//AFW_:/AFW_FSM_Drive: Tcl_Eval to drive FSM inside
Tcl modulespace. code=1 code=ERROR
Jul 4 13:02:10.199: TCL script failure
Result:
Illegal Operation: Leg not incoming or in wrong state
Jul 4 13:02:10.199: TCL script failure errorInfo:
while executing
"leg setupack leg_incoming
(procedure "act_Setup" line 8)
invoked from within
"act_Setup"
have you idea where is the problem?
we are using ccme 4.2 on a router cisco2851 with ios 12.4(11)XW6
thank in advance
Cristiano
How the related DP is configured ?
This is the configuration.
The user forward the phone to the extension 8882
application
service d2 flash://disconnect.tcl
paramspace english location flash:/aa2/
dial-peer voice 201 voip
destination-pattern 888.
session target ipv4:10.39.186.2
codec g711ulaw
dial-peer voice 202 voip
service d2
incoming called-number 8882
codec g711ulaw
I've not tested the service with forwarded calls. I suppose it would not be a big deal to make it work, but at the present time I cannot commit to that, sorry.
380
