Community Member
B-ACD doesn't work properly
Two months ago I configure the b-acd of CME and works ok with 2.1.2.2 tcl. After, we made an update of the 2801 IOS to 12.4(9)T (CME 4.0)and doesn't work ok, I mean, the welcome message is played and the menu options too, but when you try option 1 (dial-by extesion) or option 2 (hunt group) it doesnn't notice and never acts. After, second greeting is played but never it receive the options dialed. I don't know where is the problem, the b-acd configuration commands are the same and I think the version of tcl is correct with that IOS.
I have changed some commands, change the name, folders of tcl and options, but the problem continues.
Thank you very much
Fernando
Silver
Re: B-ACD doesn't work properly
Could you please upload the configuration so that we could analyze things exactly.
Hall of Fame Super Gold
which exact version of 12.4(9)T are you using? How are you connected to PSTN ?
Can you enable "debug vpm signal" and check if tones are detected ?
122
