B-ACD Internally
I am trying to configure B-ACD for internal use only. I think i have followed the document on CCO, and still iam having issues. Here is the config. Let me know what am i missing. Also attaching debugs from various modules.
dial-peer voice 301 voip
service aa
destination-pattern 4444
session target ipv4: (LoopBack)
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
service queue flash:app-b-acd-
param queue-len 20
param aa-hunt1 2222
param queue-manager-debugs 1
param number-of-hunt-grps 1
service load queue
service aa flash:app-b-acd-
paramspace english index 1
param dial-by-extension-option 5
param handoff-string aa
paramspace english language en
param max-time-vm-retry 2
param aa-pilot 4444
param voicemail 5000
param second-greeting-time 60
param welcome-prompt
param call-retry-timer 15
param max-time-call-retry 600
param service-name queue
Hall of Fame Super Red
Re: B-ACD Internally
Hi Rajesh,
Sorry to say that DSP's are required here. This does explain why you are connecting properly but are not receiving any audio.
Sorry my friend, but on the up side at least this is in the lab and not on the Customer site :)
Hall of Fame Super Gold
You' re close:
incoming called-number 4444
no service load queue <-- this is not necessary, queue starts automagically
service aa
paramspace english location flash:/ivr/ <-- suggest use a directory for that
Currently when i call the pilot number, calls gets connected however i do not hear any welcome message. After 2 minutes i get a busy tone. Here is my sh flash,
I did not quite follow when you suggest to use a directory for that.
ile Length Name/status
1 20907072 c1700-advipservicesk9-mz.124-18.bin
3 331483 CP7902080001SCCP051117A.sbin
4 338840 CP7905080001SCCP051117A.sbin
5 338424 CP7905080001SCCP051117A.zup
6 340631 CP7912080001SCCP051117A.sbin
9 497 DistinctiveRingList.xml
10 129476 P0030702T023.bin
11 459 P0030702T023.loads
12 685334 P0030702T023.sb2
13 129880 P0030702T023.sbn
14 349794 P00405000700.bin
15 350198 P00405000700.sbn
17 4000 Ring1.raw
18 4000 Ring2.raw
19 4000 Ring3.raw
20 4000 Ring4.raw
21 4000 Ring5.raw
22 497 RingList.xml
24 4668 admin_user.html
25 667582 admin_user.js
26 16948 dom.js
28 6315 ephone_admin.html
30 3831 normal_user.html
31 81600 normal_user.js
33 2451 telephony_service.html
35 10230 xml-test.html
36 3493 xml.template
37 18346 app-b-acd-
38 24679 app-b-acd-
39 33870 app-b-acd-aa-
40 75650
41 83291
42 63055
43 37952
44 496521
45 123446
46 42978
when call is connected
check sh call active voice br
then i would change as paolo suggested:
since you have already defined en as default language
I have no luck still, please clarify me if
this application needs DSP by any chance, cause this is a test lab 1761 router and have no DSP resource
Hi Rajesh,
Silly of me.. i need to find some DSP now. Thanks have a nice sunday
Paolo/Gonzalo: Thanks much for your input. Enjoy your sunday as well..
Hi Rajesh,
Not silly at all my friend! This is exactly why we lab things up.... to learn. We build and test and make mistakes every day in hopes of getting better at our chosen craft.
When we do spend time in the lab, it makes our customer builds more polished and trouble-free for them. We never learn without making mistakes. The fact that you will take the time out of your life to study shows your dedication to getting better. This is the best indication of someone who truly cares about improving!
Keep up the great work,
Now i have tried the same script on Cisco 2821 GW with enough DSP resources, and still i am stuck in the same situation. Call is connected but cannot hear welcome prompt.
Can you give me some clue where i am doing a mistake.
Now please take "voice application media state". If there is any error in filename you will see that. Also check which exact IOS you've on the 2811, certain are known to be broken. Finally, try the default prompts, if you have recorder your own chances are there is a problem isn't very easy to get the setting right for the format cisco wants.
Here is the debug voice application media state
Mar 17 20:58:07.052: //-1//TCL :EE65ACEC74000:/tcl_PutsObjCmd: TCL B-ACD: -- Optional parameter queue-manager-debugs does not exist
Mar 17 20:58:07.052: //-1//TCL :EE65ACEC74000:/tcl_PutsObjCmd: TCL B-ACD: -- Setting default to true
Mar 17 20:58:07.052: //-1//TCL :EE65ACEC74000:/tcl_PutsObjCmd: TCL B-ACD: -- Valid Mandatory parameter queue-len = 20 --
Mar 17 20:58:07.056: //-1//TCL :EE65ACEC74000:/tcl_PutsObjCmd: TCL B-ACD: -- Valid Mandatory parameter number-of-hunt-grps = 2 --
IOS version: 12.4(15)T1
CME Version: 4.1(0)
The above is output from "debug voice application script" :)
At some point you should see "playing welcome prompt", then the actual output from "debug voice application media state".
Alos suggest you load 12.4(11)XJ4, what you've now has many bugs.
What does the following warning means?
Warning: parameter number-of-hunt-grps has not been registered under aa namespace
You can ignore that, it happens for any parameter you configure for tcl/ivr.
It should be possible to have code to avoid the warning, but so far I haven't seen any source that bothers about incorporating it.
I have now IOS version of 12.4(11)T4 on cisco 1760, still has same issue. Calls gets connected, TCL script gets invoked, and for some reason the no prompt is played.
Can you tell me if it ever worked for you, if so can you give IOS and tcl script versions? I will try with exact versions. If possible config file too.
