B-ACD with SRST
I have SRST setup in CME mode. Hunt groups are working. However the customer has a UCCX Attendant queue that we are trying to mimic if the WAN link fails. The issue is when a call for that queue comes in, the B-ACD is not answering the call while in SRST/CME mode.
I have tried to setup voip dial-peers with preferences but that is not working. such as:
dial-peer voice 4000 voip
destination-pattern 4000
session target ipv4:192.168.100.151
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 4001 voip
preference 10
service aa
codec g711ulaw
no vad
I see it trying to hit both dial-peers but the AA never picks up and I get a fast busy.
However if I put this dial-peer in it works fine, but when the phones fallback to the Call Manager the main line never goes to the UCCX.
dial-peer voice 4002 pots
preference 10
service aa
incoming called-number 4000
port 0/2/0:23
So is there a way to get a call to 4000 go to the UCCX in normal operation but go to B-ACD in SRST/CME mode?
Ken
VIP Super Bronze
Re: B-ACD with SRST
You have half the battle solved at least: You have B-ACD working.
What does the rest of your dial-peer section look like? I suspect that the reason that your dial-peer 4002 always takes the call is because it is matched for the incoming dial-peer instead of whatever else you have.  My preference for doing this is to create an additional VoIP dial-peer that matches on the outgoing side and then loops the call back to the router via a loopback interface. This leaves the rest of your incoming/outgoing dial peers alone.
dial-peer voice 4002 voip
preference 2
service aa
codec g711ulaw
no vad
Re: B-ACD with SRST
Thank you for your reply,
We ended up using two dial-peers to do the hairpinning like you said.
dial-peer voice 122 voip
description Failover outbound Main Number
preference 10
progress_ind setup enable 3
session target ipv4:192.168.168.1
voice-class codec 1
no vad
Dial-peer voice 123 voip
service aa
description Hairpin to B-ACD
voice-class codec 1
no vad
We also had to setup
voice service voip
426
