Silver
B-channels stay open
I have the strange situation that an H323 gateway (2801) that is connected to a FAX server sometimes forgets to close the B-channels.
For example I execute "show voice call status" I get the message: No active calls found. But when I do a "show isdn status" I see that Layer 3 has 2 Active calls.
The result is of cource that you receive a busy tone.
Although I have not figured out what is causing this, I would like to know if there is a command that says: "if there are no active calls, clear the ISDN interface" It would saolve this problem.
Any idea?
JAn
Hall of Fame Super Gold
Re: B-channels stay open
this is software defect condition called "data structure trashing". Please state exact IOS version used on the router.
Silver
My IOS version:
c2801-spservicesk9-mz.123-14.T7.bin
I tried another version with same result.
I have never heard of this "data structure trashing" Is this a bug?
thanks,
Jan
It's when the ISDN internal data structure can't correctly keep track of channel usage.
Can you upgrade to 12.4(11)XJ4 that has many many bug fixes ?
Silver
I have upgraded the 2801 to the IOS you mentioned and it seems better. I can not really say yet because I have more issues.
This is my BRI configuration (network side)
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
isdn skipsend-idverify
And debug q921 gives this:
May 31 07:16:42.127: ISDN BR0/2/0 Q921: Net RX <- IDREQ ri=25009 ai=127
*May 31 07:16:42.127: ISDN BR0/2/0 Q921: Net TX -> IDDENY ri=25009 ai=127
*May 31 07:16:42.127: ISDN BR0/2/0 Q921: Net TX -> UI sapi=63 tei=127
*May 31 07:16:42.127: ISDN BR0/2/0 Q921: Net TX -> IDCKRQ ri=0 ai=0
*May 31 07:16:44.115: ISDN BR0/2/0 Q921: Net RX <- IDREQ ri=25209 ai=127
*May 31 07:16:44.119: ISDN BR0/2/0 Q921: Net TX -> IDDENY ri=25209 ai=127
It seems to me that the ISDN card asks for a TEI from the Cisco router, and the Cisco refuses this.
Should the Cisco give a TEI to the ISDN card since it is network side?
Mind you sometimes it suddely works,
Does any one has an idea?
Jan
Yes it should assing a TEI. In fact when using ISDN phones, I see TEI is assigned without problems, but your trace shows otherwise.
Perhaps a TEI was assigned already ?
Does it helps if you configure "isdn tei preserve" ?
What "show isdn status" say when the problem occours? What happens if you reset both router and ISDN device ?
Silver
Normally to get layer 2 up and running I must do a clear interface BRI xx and then do a test call on the BRI (test isdn call int bri XX 123) and then layer2 gets up.
Before that I see TEI assigned.
I am already quite some time bussy with this problem and yesterday evening I changed the configuration to:
interface BRI0/1/0
no ip address
isdn static-tei 0
The static-tei seems to work now.
I can't send you deb q921 yet, because this I have at my home PC.
I have made network side configurations in the past, and normally this doesn't give so much trouble as this configuration connecting to a FAX server with ISDN card.
Thanks for your help btw :)
Jan
I had the same problem bith BRI interface, connecting to PSTN network. It did not work until I did not enter the comand
isdn static-tei 0
I have noticed that so many users have the same problem.
regards,
alicic
147
