BACD prompt is not play
I triyng to setup BACD [AA+ 2 hunt group (1111,2222)]. I call the pilot number 8000, the call is answered (Dial-peer 1000) but the welcome prompt is not play. I'm also received this next warning when the parameters are modify:
CME-Lab(config-app-param)#  param aa-hunt2 2222
Warning: parameter aa-hunt2 has not been registered under csq namespace
SETUP
application
service aa flash:/bacdprompts/app-b-acd-aa-2.1.0.0.tcl
  paramspace english index 1
  paramspace english language en
  paramspace english location flash:/bacdprompts/
  param welcome-prompt en_bacd_welcome.au
  param handoff-string aa
  param service-name csq
  param aa-pilot 8000
service csq flash:/bacdprompts/app-b-acd-2.1.0.0.tcl
  param queue-manager-debugs 1
  param aa-hunt1 1111
  param number-of-hunt-grps 3
  param queue-len 15
  param aa-hunt2 2222
dial-peer voice 1000 pots
service aa
incoming called-number 8000
ephone-hunt 1 sequential
pilot 1111
list 2001, 2002
ephone-hunt 2 peer
pilot 2222
list 2003, 2004
Thanks in advance
Please remember to rate useful posts clicking on the stars below. Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo. ___________________________________________ LinkedIn Profile: do.linkedin.com/in/leosalcie
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Play Failed
    while executing
"media play leg_incoming moh:livemoh"
Either MoH is not configured, or you're hitting bug CSCsd14203 (need support contract to see bugs).
This is very ofent asked and if you had searched before asked, you would haved a query anhd time.
Anyway:
The warning is normal and expected.
You can take "debug voice application script" and debug voice application media status" with" term mon" to see what is heppening.
Ok, now the prompt is play but call are no transfer to the queue Option 1: hunt 1111 and Option 2: 2222, I don't know whay...any idea?
service aa
pilot 1111
list 2001, 2002
ephone-hunt 2 peer
pilot 2222
list 2003, 2004
application
  param number-of-hunt-grps 2
  param aa-hunt1 1111
  param aa-hunt2 2222
  param queue-len 15
  param aa-pilot 8000
  param dial-by-extension-option 3
  param second-greeting-time 30
  param call-retry-timer 15
  param max-time-call-retry 120
  param max-time-vm-retry 2
  param voice-mail 8000
Check debugs indicated above.
@Paolo, I received this output:
CME-Lab#
Aug  2 19:53:26.080: //60//TCL :/tcl_PutsObjCmd:
proc init_perCallvars
Aug  2 19:53:26.080:
Aug  2 19:53:26.084: //60//TCL :/tcl_PutsObjCmd: TCL AA: ++ Playing Welcome Prompt and options menu ++
Aug  2 19:53:26.112: %ISDN-6-CONNECT: Interface Serial0/2/0:1 is now connected to 3001 N/A
Aug  2 19:53:31.140: //60//TCL :/tcl_PutsObjCmd: TCL AA: +++ No option selected +++
Aug  2 19:53:36.284: //60//AFW_:/AFW_FSM_Drive: Tcl_Eval to drive FSM inside Tcl modulespace. code=1 code=ERROR
Aug  2 19:53:36.284: TCL script failure
        Result:
                         Play Failed
Aug  2 19:53:36.284:    TCL script failure errorInfo:
                        Play Failed
    while executing
    ("default" arm line 15)
    invoked from within
"switch -exact $optionSelected {
                                        act_RetryMenu
                                {0} {
                                        act_GotDestNoOption
                                default {
                                        set playMusicFlag 1
    (procedure "act_GotDest" line 31)
    invoked from within
"act_GotDest"
Aug  2 19:53:36.288: //25//TCL :/tcl_PutsObjCmd: TCL B-ACD: +++ New incoming call to queue 2222 +++
Aug  2 19:53:36.288: //25//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> THE QUEUE IS {TclModule_4A74A938_0_21999552 {CALL_NEW} {1343937216}} <<<
Aug  2 19:53:36.292: //25//TCL :/tcl_PutsObjCmd: TCL B-ACD: +++ 2222 Queue Length = 1 +++
Aug  2 19:53:36.304: %ISDN-6-DISCONNECT: Interface Serial0/2/0:1  disconnected from 3001 , call lasted 10 seconds
Aug  2 19:54:18.577: //25//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> B-ACD Service Running <<<
Aug  2 19:54:18.577: //25//TCL :/tcl_PutsObjCmd: TCL B-ACD: >>> {TclModule_4A74A938_0_21999552 {CALL_NEW} {1343937216}} <<<
Aug  2 19:54:18.577: //25//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> THE QUEUE IS  <<<
Aug  2 19:54:18.581: //25//TCL :/tcl_PutsObjCmd: TCL B-ACD: +++ AA TclModule_4A74A938_0_21999552 not responding, flushed from Queue +++
Play Failed
    while executing
I just added this two line:
  moh music-on-hold.au
multicast moh 239.1.1.55 port 2100
Thanks for the support Paolo
The 2nd command shouldn't be even needed.
Thank you for the nice rating and good luck!
797
