12-23-2009 05:51 AM - edited 03-15-2019 08:52 PM
Is it possible to have 7985's have custom backgrounds?? Tried googling but am struggling to find any info.
Solved! Go to Solution.
12-23-2009 06:41 AM
Hi Weeyin,
They will need to be in;
Directory "/Desktops/800x600x16"
Have a look at this great post from Martin. He has broken down the different sizes required
and the method for changing them;
7941 / 7961
Full size image- 320 pixels (width) X 196 pixels (height).
Thumbnail image- 80 pixels (width) X 49 pixels (height).
Directory "Desktops/320x196x4"
7942 / 7962
Full size image-320 pixels (width) X 196 pixels (height).
Thumbnail image-80 pixels (width) X 49 pixels (height).
Directory "/Desktops/320x196x4"
7945 / 7965
Full size image-320 pixels (width) X 212 pixels (height).
Thumbnail image-80 pixels (width) X 53 pixels (height).
Directory "/Desktops/320x212x16"
7970 / 7971
Directory "Desktops/320x212x12"
7975
Full size image-320 pixels (width) X 216 pixels (height).
Directory "/Desktops/320x216x16"
Hope this helps!
Rob
12-23-2009 05:58 AM
Hi Weeyin,
Most possible my friend
For the 7985 the List.xml should look like this;
URL="TFTP:Desktops/800x600x16/logo7985.png"/>
Hope this helps!
Rob
12-23-2009 06:02 AM
If I just add in the code to the List.xml file will it then display on the 7985 options? Do i need a certain version of firmware?
12-23-2009 06:12 AM
There are no specific firmware requirements for this. You will need to restart the TFTP service after uploading/changing files in it.
Here's the documentation on the specifics. Background image documentation starts on page 95.
12-23-2009 06:27 AM
Not having any joy with this one, have managed to get the files uploaded to the Desktops/800x600x16 folder and have updated my List.xml file but instead of the background being displayed on my 7985 phone I am getting it as available on my 7945 phones!
My list file resides under the Desktops/320x212x16 folder, do I need one at a higher level instead or should it be in the 800x600 directory??
At the moment all I get when i go into background images on the 7985 phone is "DEFAULT" no other options are available.
Am on v6.1 of callmanager
12-23-2009 06:41 AM
Hi Weeyin,
7941 / 7961
7942 / 7962
7945 / 7965
7970 / 7971
7975
Hope this helps!
Rob
12-23-2009 07:36 AM
Thanks for all your help guys, finally got it to work once I created a List.xml within the Desktops/800x600x16 folder!
