Background image in CME for 7965 phone
Hi There,
I am trying to configure background image in cme for 7965 phones but don't see any document on that other than 7970/71/75 so therefore i'm curious whether is it doable or not?
any input will be appreciated.
Muddasir
1 ACCEPTED SOLUTION
Re: Background image in CME for 7965 phone
Yes, it's doable.
Just the image size and directory differ for that model:
7945 / 7965
Full size image—320 pixels (width) X 212 pixels (height).
Thumbnail image—80 pixels (width) X 53 pixels (height).
Directory "/Desktops/320x212x16"
The rest of the config is the same, List.XML, tftp, etc.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Yes, it's doable.
7945 / 7965
java
java
Thank very much for your input dude!
i will try it and see if it works or not.
Muddasir
It did work. Thanks very much dude!
Muddasir
2634
