Background image path
I want to set the path to a corporate backgound image on 8945 phones. There is a field labeled "in the Product Specific Configuration Layout of the phone.
Help says "This parameter specifies the default wallpaper file. Only the administrator disables end user access to phone wallpaper list, could this parameter take effect."
The image and List.xml are accurate and I can set manually the image as backgroung.
I've also set the setting access to disable as asked in order to prevent access to wallpaper list.
I tried different path in the Backgroung field without success...
Does someone has the good path syntax to reach /Desktops/648x480x24/imagecorp.png   ?
Everyone's tags (4)
1 ACCEPTED SOLUTION
You need to be running FW 9.3(1), under common phone profile you need to uncheck the option "enable end user to access phone background", the path for the files seem to be correct. Make sure to restart the TFTP and just input the filename in that field, not the whole path.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
Perfect !
Thanks Java.
1256
