06-26-2009 10:25 AM - edited 03-15-2019 06:42 PM
Hello All,
I was just reading the below thread:
Java mentioned that a tool would be available in CUCM 7 that would enable us to push background images in bulk to phones.
I have a customer with CUCM 7 that would like this functionality.
Does anyone know whether or not this tool actually came with the 7.x release, and if so, where can I find it.
Any help, as always, is greatly appreciated.
Thanks in advance,
06-26-2009 11:57 AM
The only one that they provided in the end was the Cisco Phone Designer, and it doesn't have the bulk ability.
java
if this helps, please rate
06-26-2009 12:17 PM
Thanks Java,
Would you happen to know of any 3rd Party apps that can handle it? The only one I found says it only supports 3.x, 4.x, and 5.x.
07-28-2009 07:32 AM
Did you locate any info. on this? I need to do the same
