03-26-2008 11:15 AM - edited 03-15-2019 09:39 AM
Are there backgrounds images available for 7941/7961 and 7945/7965?? I have only seen for 7970.
03-26-2008 11:33 AM
03-26-2008 11:37 AM
Hi Matthew, my problem is not how to configure backgrounds images, what I am asking is for backgrounds images demostration, some good photos to add as in 7970 is available.
03-26-2008 11:53 AM
The same photos that you can add on the 7970, you should be able to add on the 7945/7965, as long as you adjust the image to the parameters that cisco specifies.
03-26-2008 12:05 PM
Ok Kenneth, I'll try it.
