Background images
Are there backgrounds images available for 7941/7961 and 7945/7965?? I have only seen for 7970.
Re: Background images
Hi Matthew, my problem is not how to configure backgrounds images, what I am asking is for backgrounds images demostration, some good photos to add as in 7970 is available.
The same photos that you can add on the 7970, you should be able to add on the 7945/7965, as long as you adjust the image to the parameters that cisco specifies.
Ok Kenneth, I'll try it.
349
