Community Member
Backup CCM for desatry recovery
Does anyone cret a network folder to use as Network Backup devive on Callmanager ver 6?
With SFTP server it should be use ?
1 ACCEPTED SOLUTION
Community Member
Re: Backup CCM for desatry recovery
are you providing DNS name under server name field or ip address? If DNS, check CCM can resolve the name to ip address of the sftp server. you should specify \ as the path name so that it goes into the root of the sftp.
The only options are:
•Archive backups to a physical tape drive or remote sftp server.
Disaster Recovery System Administration Guide for Release 6.0(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/6_0_1/drs/drsag601.html
Try FREEFtpd
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
I agree with freeftpd. it is the best one I have seen for ftp and sftp. moreover it is free.
Community Member
I am trying to find FREEFtpd but all the links apears to be broken
Someone cant share it with me?
Brgds
Community Member
Hi Guys
I found it
But I am receiving the following error when I try to creat a device
"Unable to access SFTP server. Please make sure the login credentials and path are correct."
But allthi information is correct , even in the server I am seeing that The CCM connect to the server
Any help?
Community Member
Community Member
Yes I am using the IP
Specifying \ as the path name , solve the problem
Thaks a lot
Community Member
no problem. good to hear it solved it.
182
