Backup CCM5
I upgrade CCM5.1 to 5.1.3. I used the patch cisco-ipt-k9-patch5.1.3.2000-3.tar.gz.sgn.
All the services are ok, but the backup not!
In the Recovery don't show me feature to select. Show me the message "Not features found"
Someone have any idea about it?
Re: Backup CCM5
are the DRF services running?
if not, start them.
If yes, restart them =)
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Re: Backup CCM5
Javalenc, hi!
Where I can restart the disaster recovery (DRF) in CCM 5.1.3?
Re: Backup CCM5
CUCM serviceability
java
Re: Backup CCM5
Thanks Javalenc!!!
Thank you very much!
Re: Backup CCM5
Hi pgcristovam, I am make a CCM5.1.2.3000 to CCM5.1.3, and I download cisco-ipt-k9-patch5.1.3.2000-3.tar.gz.sgn,cisco-ipt-k9-patch5.1.3.1000-12.tar.gz,cisco-ipt-k9-patch5.1.3.3000-5.tar.gz, but when I Installation/Upgrade one of these patches, I met Status:Errors encountered.
I don't know how I can slove the issue, do you have any suggestion? Thanks in advanced.
Re: Backup CCM5
What Errors was encountered?
166
