BACKUP error
Server : CUCM
Feature : UCM
Component : TFTP
Time Completed: 2014-06-05-20-47-45
Result Code : 116-SFTP transfer failed during Backup. Either there is not enough disk space or
network transfer failed due to interuption while transferring data to configured SFTP Server
Result String : ERROR
Free space on /common/drf = 8265088 KB, required space = 1961508 KB
Ready for backup
./P00308000500.loads
./CP7905080001SIP060412A.sbin
./CP7921G-1.2.1.LOADS
./WLAN-1.0.3.SBN
./SYS-1.4.4.3.SBN
etc etc
What SFTP tool are you using
What SFTP tool are you using?
Yosh
HTH Regards, Yosh
what sftp client? These SFTP
what sftp server?
These SFTP servers are supported and recommended. You can use any one of these SFTP servers:
From: http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/110309-callmanager-backup.html
Kevin,+5 on the great info!
Kevin,
+5 on the great info! To add on to this info, you could also use freeFTPd.
Yosh
HTH Regards, Yosh
Thanks!  I use freeFTPd as
Thanks!  I use freeFTPd as well, but its off the official list now per some limitations (see link: https://supportforums.cisco.com/document/54311/how-configure-freeftpd-unified-communications )
As his backup here is over 1GB, he may be hitting bug : CSCsm21349
thanks kevintitanftp worked
thanks kevin
titanftp worked for me
I am using freeftpd, I think
I am using freeftpd, I think becz of the file size the freeftpd is prompting with an error.
That's funny my backups are
That's funny my backups are over 1GB and I don't have any issues.
Yosh
HTH Regards, Yosh
352
