Community Member
Backup Fail on Callmanager 5.1
Hi, i need you help. I can't to make a backup. The follow message appear:
ERROR: Error, unable to move tar file to: /common/drf/2007-11-12-14-25-28/2007-11-12-14-25-28_SUB-LAFARGECH_CCM_LOCALE.tar,
Pls.see the attachments.
Any idea?
Community Member
Re: Backup Fail on Callmanager 5.1
Hi Cristian,
Have you installed the Locale in both or all servers Pub and Sub? How many CCM do you have?
Community Member
I'm going to check it.
Community Member
I`m working with Cristian in this instalation. I`ve loaded locale and moh files on both servers, and error still appears.
This is bug ID CSCsi87942.
Community Member
Hi Adam
In the bug toolkit say does not exist.
Regards.
Community Member
I've made an upgrade to CCM 5.1(3) but it didn't resolve the problem. The message error is the same.
On you post you've said it's a bug, but the ID doesn't work, can you check again the ID?
TIA
Community Member
The but ID is CSCsi80320
We are having the same issue. We are going to be using 5.1.2.3000-2 to fix the issue.
Community Member
We solved this issue with a TAC Case. The upgrade was to 5.1.3-1000 and then I've uploaded again the locale.
When the CCM synchronized the DRS, the issue was solved.
I hope this works for you.
Andres
557
