Backup for IPCC Express
With IPCC Express on the Backup Storage Location Page, there is a text box to put in "Path Name". What format do you do this in since the format I will list below did not work.
\\Gummi\home\ipcc
Gummi is the name of the server, do I need to put the IP Address instead?
1 REPLY
Hall of Fame Super Silver
Re: Backup for IPCC Express
Either one should work, if you are putting hostname make sure DNS can resolve it, try pinging it from the machine.
Also instead of doing home\ipcc I would share the ipcc folder and then simply use \\Gummi\ipcc format.
HTH,
Chris
127
