backup line
zeuscyril
Level 4
Level 4
Hi friends,
I installed cisco call manger 6.1 with PRI line.
i configure every thing working well and good.i need one backup for pri line so i purchased 4 analog lines .
my question is how i need to configure the 4 analog line as a backup line for pri ,if pri goes off we need to use these analog line.
help me regarding this matter.
thanks
6 Replies 6
paolo bevilacqua
Are you using h.323 or mgcp ?
i am using mgcp
I don' think automatic backup can be done with mgcp. Others can give better advice.
Configure Route Groups and Route Lists with the PRI in 1st place and then analog ports
java
if this helps, please rate
java
sorry,
i am not able to get your idea, can u please explain brief in the same..
Read this to understand
Call Routing in Unified CM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/dialplan.html#wp1044129
java
java
