backup line
Hi friends,
I installed cisco call manger 6.1 with PRI line.
i configure every thing working well and good.i need one backup for pri line so i purchased 4 analog lines .
my question is how i need to configure the 4 analog line as a backup line for pri ,if pri goes off we need to use these analog line.
help me regarding this matter.
thanks
  • IP Telephony
Hall of Fame Super Gold
Re: backup line
Are you using h.323 or mgcp ?
Re: backup line
i am using mgcp
Re: backup line
I don' think automatic backup can be done with mgcp. Others can give better advice.
Re: backup line
Configure Route Groups and Route Lists with the PRI in 1st place and then analog ports
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: backup line
sorry,
i am not able to get your idea, can u please explain brief in the same..
Re: backup line
Read this to understand
Call Routing in Unified CM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/dialplan.html#wp1044129
java
java
121
