08-14-2010 05:16 PM - edited 03-16-2019 12:15 AM
Backup Notifications
After a backup is successful or failed can the CUCM platform send an e-mail notification upon running.
08-14-2010 07:37 PM
I don't believe so. However, I think that there might be an option where
you leverage the application log/syslog to an offbox syslog server. Then
you can script an alert from there.
HTH.
Bill
On 8/14/10 8:16 PM, "blackmichael"
08-14-2010 07:59 PM
Thanks for the reply. that sounds doable but i would suggest to Cisco to add this as an enhancement. It would be horrible to have a backup scheduled not to have it when you need it since something like the SFTP service stopped on the server something like that.
