Backup Notifications from CUCM
After a backup is successful or failed can the CUCM platform send an e-mail notification upon running.
Re: Backup Notifications from CUCM
I don't believe so. However, I think that there might be an option where
you leverage the application log/syslog to an offbox syslog server. Then
you can script an alert from there.
HTH.
Bill
On 8/14/10 8:16 PM, "blackmichael"
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Thanks for the reply.  that sounds doable but i would suggest to Cisco to add this as an enhancement.  It would be horrible to have a backup scheduled not to have it when you need it since something like the SFTP service stopped on the server something like that.
281
