Backup Strategy of Cisco Voice Servers
John Huthmaker
Level 4
Level 4
Hey Everyone,
My boss mentioned to me that he wants to start making backup's of our cisco voice enviornment.  Currently we have 4 servers.
1) UCCX
2) Unity
3) UCMPU
4) UCMSUB
All of these servers are build with a RAID 1 mirror.  He mentioned that typically people will pull one hard drive to keep as a backup, and then rebuild the mirror with a new blank hard drive.
Is this something anyone can speak to?  It sounds pretty straightforward, but I want to find out if there is a typical procedure you would follow for this.  I've done similar things with Windows servers, but never in a cisco enviornment.
Jaime Valencia
Just an FYI, we do not support that as a backup method. We only support swapping HDDs in case of failure.
Otherwise, just use the backup method for each product that we provide.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Rob Huffman
Hi John,
I'll just add a reference to the great tips from my friend Java (+5 "J") Bosses always
want to see these things in writing
Removing Hard Drives
Cisco only supports replacing failed hard drives. Cisco does not support  drive pulling/swapping as a method of fast upgrade reversion, restore,  or server recovery. For information on replacing a failed hard drive,  refer to the Troubleshooting Guide for Cisco Unified Communications Manager.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_3/cucm-rel_notes-713.html#wp1600579
So...DRS is your best friend here;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/7_1_2/drsag712.html
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
