::: Bad Clocks :::
Urban_Nights
when I restart the physical connection I receive the following error:
%TRUNK_CLOCK-6-BAD_CLOCKS: There are no good clocks in the system. Remain in HOLDOVER mode
And I am not able to establish Layer 1.
The clock missing can cause this issue?
With best regards and thanks.
Try configuring framing no-crc4 under controller.
8 Replies 8
paolo bevilacqua
Which exact router and interface is that ?
the interface is:
interface Serial6/4:15
no ip address
encapsulation hdlc
isdn switch-type primary-dpnss
isdn incoming-voice modem
isdn bind-l3 iua-backhaul as-mg
isdn dpnss pbxA
no cdp enable
Serial6/4:15 is down, line protocol is down
Hardware is DSX1
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Last input never, output never, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 carrier transitions
Timeslot(s) Used:16, Transmitter delay is 0 flag
The router is the Media Gateway AS5400:
System returned to ROM by reload at 12:52:30 UTC Tue Jul 18 2000
System image file is "flash:c5400-is-mz.124-15.T5.bin"
Cisco AS5400XM (BCM) processor (revision 0x22) with 393215K/131072K bytes of memory.
Processor board ID JAE114742M6
SB-1 CPU at 750MHz, Implementation 1025, Rev 0.3, 256KB L2 Cache
Last reset from IOS reload
Manufacture Cookie Info:
EEPROM Version 0x4, Board ID 0x4BD,
Board Hardware Version 2.7, Item Number 800-6572547-03,
Board Revision A0, Serial Number JAE114742M6.
Processor 0x0, MAC Address 0007.0e58.9416
2 Gigabit Ethernet interfaces
103 Serial interfaces
16 Channelized E1/PRI ports
512K bytes of NVRAM.
125440K bytes of ATA External CompactFlash (Read/Write)
Thank you for your effort.
Best regards.
Seems to me your circuit is down. If you do "show controllers T1" you will likely see "loss of singal" or other major error.
Yes is true :)
in my case is E1.
I can see Receiver has loss of frame..so, this means that I have a problem in the remote link side?
E1 6/4 is down.
Applique type is Channelized E1 - balanced
alarm-trigger is not set
Version info of slot 6: HW: 1032, PLD Rev: 7
Framer Version: 0x9
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x03,
Board Hardware Version 4.8, Item Number 73-3996-05,
Board Revision A1, Serial Number JAE11474BPF,
PLD/ISP Version , Manufacture Date 24-Nov-2007.
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (535 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
322 Slip Secs, 535 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 535 Unavail Secs
Total Data (last 86 15 minute intervals):
18931 Line Code Violations, 26266 Path Code Violations,
46558 Slip Secs, 77400 Fr Loss Secs, 22 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 77400 Unavail Secs
Thank you for your efforts.
With regards.
Very very good!
Layer 1 is active!
Thank you a lot for your efforts.
E1 6/4 is up.
No alarms detected.
Framer Version: 0x9
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (177 seconds elapsed):
205 Line Code Violations, 4095 Path Code Violations
34 Slip Secs, 45 Fr Loss Secs, 5 Line Err Secs, 0 Degraded Mins
10 Errored Secs, 0 Bursty Err Secs, 4 Severely Err Secs, 42 Unavail Secs
Data in Interval 1:
541 Slip Secs, 900 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
Data in Interval 2:
3237 Line Code Violations, 13701 Path Code Violations
532 Slip Secs, 900 Fr Loss Secs, 8 Line Err Secs, 0 Degraded Mins
Data in Interval 3:
542 Slip Secs, 900 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
Data in Interval 4:
543 Slip Secs, 900 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
Data in Interval 5:
Data in Interval 6:
Data in Interval 7:
Data in Interval 8:
Data in Interval 9:
Data in Interval 10:
Data in Interval 11:
Data in Interval 12:
Data in Interval 13:
0 Line Code Violations, 0 Path Code h
Now I will try to connect MGC via IUA/SCTP.
Thank you and regards.
No problem.
Thanks for the appreciation and good luck!
It's me who should thank you.
Thank you.
Good luck for you too.
