12-01-2011 07:51 AM - edited 03-16-2019 08:20 AM
hi all,
when i enter a new router 2801-v , i found the info in CLI
Time out, no test result is received from DSP!
and when i do the show voice dsp detailed , the output are:
Router#show voice dsp detailed
----------------------------FLEX VOICE CARD 0 -----------------------
*DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND : (bad)bad (shut)shutdown (dpend)download pending
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 None 0.0.0 bad idle 0 0 0 0/0
C5510 001 02 None 0.0.0 bad idle 0 0 0 0/0
C5510 001 03 None 0.0.0 bad idle 0 0 0 0/0
C5510 001 04 None 0.0.0 bad idle 0 0 0 0/0
C5510 001 05 None 0.0.0 bad idle 0 0 0 0/0
C5510 001 06 None 0.0.0 bad idle 0 0 0 0/0
C5510 001 07 None 0.0.0 bad idle 0 0 0 0/0
C5510 001 08 None 0.0.0 bad idle 0 0 0 0/0
*DSP SIGNALING CHANNELS*
C5510 001 01 {flex} 0.0.0 free idle 0 0 0/0/0 0 0/0
C5510 001 02 {flex} 0.0.0 free idle 0 0 0/0/1 0 0/0
C5510 001 03 {flex} 0.0.0 free idle 0 0 0/0/2 0 0/0
C5510 001 04 {flex} 0.0.0 free idle 0 0 0/0/3 0 0/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
it seems that the DSP current status is bad, i want to know is there any thing i should do before i use the dsp recourse? or I should do a RMA to get a new PVDM card?
and there are some other show and debug output.
Router#show voice dsp group all
DSP groups on slot 0:
dsp 1:
State: FAIL, firmware: 0.0.0
Max signal/voice channel: 8/8
Max credits: 160
num_of_sig_chnls_allocated: 4
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 160, reserved credits: 0
Signaling channels allocated: 4
Voice channels allocated: 0
Credits used (rounded-up): 0
0 DSP resource allocation failure
Router#
Router#
Router#show diag
PVDM Slot 0:
8-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8848-05
Board Revision : A0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC101410
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-8
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 04 30 41 04 00 82 49 22 90 05 42 41 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 30 31 34
0x20: 31 30 48 47 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 87 50 56 44 4D 32 2D 38 89 56 30 31 20 D9 02 40
0x40: C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
VIC Slot 0:
2nd generation - FXO Voice daughter card (4 port)
Hardware Revision : 5.0
Top Assy. Part Number : 800-21589-01
Board Revision : E0
Deviation Number : 0-0
Fab Version : 04
PCB Serial Number : FOC09290M
RMA History : 00
Product (FRU) Number : VIC2-4FXO=
0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 01
0x10: 42 45 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 30
0x20: 39 32 39 30 4D 4A 36 03 00 81 00 00 00 00 04 00
0x30: 89 56 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
thanks in advance.
yu.
12-01-2011 08:46 AM
Not sure if this will help
Can you try
conf t
voice-card 0
Then look at the DSP
show voice dsp det
Alex
12-01-2011 09:27 PM
but it seems not work, there are already configured the voice-card command in the running configure before i try to configure it.
yu.
12-01-2011 11:33 AM
Something you could try is to reset that dsp module.
use the 'test voice driver' command.
- select the slot number it is installed in
C3800 Debugging Section;
1 - FPGA Registers Read/Write
2 - 5510 DSP test
3 - DSPRM test
4 - HDLC32 test
5 - TDM test
6 - Quit
- select option 2
5510 DSP Testing Section:
1 - Reset ALL DSPs
2 - Reset 1 DSP
3 - Download Bootload DSPware
4 - CHPIR Enable/Disable
5 - Display c5510 ring
6 - Show HPI RAM
7 - Show eHPI memory thru Relay command
8 - Show Controller
9 - c5510 Keepalive Enable/Disable
10 - Download bootloader using indirect slave access
11 - Write HPI RAM
12 - DSP application download
13 - faked dsp crash
14 - Wait in Firmware Restart Indication
15 - Display DSP Keepalive Status
16 - QUIT
- select option 2 to reset the DSP
I would also suggest check the keepalive status as well. I could be that the DSP is not installed properly as well and may need to be reseated before doing an RMA.
J
12-01-2011 09:37 PM
Router#test voice driver
Debugging Section;
2 - 5510 DSP test
3 - DSPRM test
4 - Quit
Select option : 2
1 - Reset ALL DSPs
2 - Reset 1 DSP
3 - Download DSPware
6 - Show HPI RAM
8 - Show Controller
10 - Use PCI to download
11 - Write HPI RAM
16 - QUIT
Select option : 2
Enter DSP id : 1
1 - Reset ALL DSPs
2 - Reset 1 DSP
6 - Show HPI RAM
8 - Show Controller
11 - Write HPI RAM
16 - QUIT
Select option : 0
1 - Reset ALL DSPs
2 - Reset 1 DSP
6 - Show HPI RAM
8 - Show Controller
11 - Write HPI RAM
16 - QUIT
Select option : 2
Enter DSP id : 2
DSP 2 is not present.
1 - Reset ALL DSPs
2 - Reset 1 DSP
6 - Show HPI RAM
8 - Show Controller
11 - Write HPI RAM
16 - QUIT
Select option : 16
Debugging Section;
2 - 5510 DSP test
3 - DSPRM test
4 - Quit
Select option : 4
Router#sh voice dsp de
12-02-2011 11:15 AM
Hey Yu,
Sorry guess I didn't clarify enough. I didn't mean removing the logical config. But actually powering down the router and checking to make sure the pvdm is firmly seated into the slot.
If you are getting no keep alives from the dsp then a dspware upgrade will not fix the issue. It is most likely a physical problem and would need to be rma'ed after you make sure it is physically seated correctly into the slot.
J
12-01-2011 10:22 PM
Router(config)#voice-card 0
Router(config-voicecard)#dsp ser dsp
Router(config-voicecard)#dsp ser dspfarm
Router(config-voicecard)#exi
Router(config)#dsp profile 2 ?
conference Profile type Conference
mtp Profile type MTP
transcode Profile type Transcoding
Router(config)#dsp profile 2 tr
Router(config)#dsp profile 2 transcode
Dspfarm profile 2 :: No resource, check voice card or dspfarm service is not configured
Router(config-dspfarm-profile)#
12-02-2011 06:27 AM
Hello Yu,
I think that last test you can go ahead is to upgrade the DSPware... How? By upgrading the IOS to a newer version... The "show dsp group all" shows state as failed which is not good... So maybe you can test upgrading IOS and DSPware, then you can issue "show voice dsp group all" and see what's the result...
Jorge
