Bandwidth limitation !
Hi there !
My company has a branch with 4 IP Phones and I'd like to create a restriction allowing only 2 calls simultaniously...
I'm thinking of creating a LOCATIN for those IP phones and use 96kpbs for 2 calls (g729)
Is this the right way ?
Is there any other ?
Andrei.
  • IP Telephony
1 ACCEPTED SOLUTION
Re: Bandwidth limitation !
You can change the message in the service parameters although I don't understand what you mean by "how can I change this message for a busy tone". Can you explain?
Silver
I suspect you may be looking for Call Admission Control CAC:
<http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/voipsol/cac.htm>
hth,
Ajaz
Well, it's something like that... but it seems that CAC only works with a voice gateway.. and that branch does not have a voice gateway, it's there only for QoS and routing functions...
I made I trial with LOCATIONS on CallManager (4.2) .. I created a location with 80kbps and it worked for only one call because it's using G711...
I don't understant why, because I configured All regions for g729...
Any idea on how can I make g729 ?
Andrei.
Make sure that all phones have a region assigned to them.
Also 96 Kb/s is way too much bandwidth if you are looking to restrict calls to 2 G729 calls.
I create a new region and checked all configuration.. now it's working with g729... (24kbps per call)
Now I see a message on phone screen saying that there is not enough bandwidth... how can I change this message for a busy tone ?
Well, users don't know what is "not enought bandwidth".. but if they hear a busy tone insted, they'll know that cannot make that call at that moment.
But I changed the message to "All lines are busy".. I think it's ok now !
Thanks a lot.
Andrei.
114
