Bandwidth per Call Onhold
If we have a total of 10 incoming calls in queue in a call center, and 5 of them are being answered by the reps, and the remaining 5 calls are waiting in queue and customers would listen to music while on hold at this point. Does anyone know how much bandwidth is being used for each call on hold? I think it's taking the same amount of bandwidht per VoiP call, which is approx. 90kbps. I am running mgcp, g711ulaw over ethernet.
Thanks for any input.
hieu
Re: Bandwidth per Call Onhold
This is correct if you're using unicast MOH. If you're using multicast MOH, the bandwidth consumption would be considerably less as all phones would be listening to the same multicast stream.
Brandon
Thanks Brandon for your response. I don't acutally manage the Cisco Call Manager, so is there a way to verify that MOH is unicast or multicast?
thanks!
hieu
I found the answer to my own question. I'll get in touch with the Call Manager admin, so he can check the setting on the server.
hieu
Unicast is the default. In Callmanager, the MOH server, MOH audio source and the media resource group must all be enabled for multicast for MOH to be delivered via multicast. You could check these settings. You could also use a sniffer to see if the packets are coming from a multicast address.
Brandon
Thanks again, Brandon. Yep, our system is currently set for "unicast", so I'll look into changing it to "multicast" to see if it's helping out with the bandwidth issue..
hieu
165
