Bandwidth utilization in IPT
How the bandwidth is utilized in IP Telephone?
Re: Bandwidth utilization in IPT
Hello
It depends on the settings on your call manager. Please check the codec settings in "regions" on the Call manager administration page.
Basically if you are using G.711 within the same call manager cluster it would be approximately 85kbps.
Following is the good reading from cisco
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080094ae2.shtml
We use G.711 within the region. Can't we use G.729 within the region and G.711 for other regions?
If I am calling from one IPT to other IPT, which bandwidth will be used? WAN Bandwidth or bandwidth configured for IPT (Location)?
Case 1: -
2 IPTs in one room, going into one switch and then CM. Which Bandwidth is used by the Location field.
Case 2: -
One IPT is in one room and 2nd IPT is placed in another location over the WAN. Call Manager is handling the call and sends the request to router which is connected to WAN. Router Bandwidth is used or bandwidth configured for IPT in Location field?
Case-1
Please confirm the bandwidth settings for phones. You can find out from the device pool, if both phones are in the same device pool, and codec being used is G711, than approximately 80kbps is used per call
Case-2
If the phones are in two different regions, and check the codec settings betweeen the regions, if it is G729 approximately 30kbps is used if it is G711 approximately 80kbps is used. If anyother codec is used you have to calculate using the bandwidth tool i posted in my earlier post.
hi,
thank you very much rajeshrevuru for documentation.
i have another question: how much bandwith is used just for signalisation of a call.
thanks a lot
150 bps per stream for call control
java
if this helps, please rate
www.cisco.com/go/pdi
hi,
thanks javalenc,
if i have 3 sites A,B and C
and i have 2 CM, (CM1:avaya) in site A and (CM2:call manager) in site B.
and i have gatway (avaya) in site C.
i have link betwwen site A and C and link between sites B and C
i have ipphones (avaya) in site C, who is controlled bye CM1, and i have ipphones (cisco) in site C who is controlled bye CM2.
and i have trunk with CM1 and CM2.
i want to know if ipphone in site C calls ipphone in site B, how much bandwidth is used in link between site A and C.
there is architecture in attachement file.
thank you
that depends on the region you have set between the elements as already explained in previous threads
go into your config and look the device pool from your devices, it contains the region they are configured to use.
then look for the other device pool and compare the region, if they're not in the same DP look into the region config, there you will see which codec will be used
we cannot tell you how much BW since that depends on the config you have
the BW will depend on the region to which the endpoints involved in the call are located in
java
hi,
the devices are not in the same DP.
and we use G729 codec
thanks
then they should be using 24 kbps per call, that is covered in the link that was already posted in the before threads. have you had some time to go thru them?
java
hi,
i know i read it, but i want to know bandwidth used just for indication of a call. the file posted explain the situation.
thankyou very much
OK, for the pure RTP should be 64 kbps for G711 and 8 kbps for G729.
Depending on the underlying technology usually the calculation is 80 kbps G711 and 24 kbps G729 including all layer 2 headers.
that are only the RTP packets with all layer 2 and 3 headers.
the signaling for the call is 150 bps and must be added per call
java
thankyou verry much
440
