Community Member
Barcode Scanners
Hi all,
We are looking to scan in MAC address' via the barcode on the box.
Is there a certain sort of barcode reader we need to purchase?
Can anyone recommend one?
Thanks in advance for any help
Hall of Fame Super Red
Re: Barcode Scanners
Hi Jamie,
This tool is a definite must that's for sure :)
We use the Symbol LS2208 shown @ the link below. This has worked very well for us :)
There are also many others listed in this good link from "The Kid";
Hope this helps!
Community Member
Hello Rob,
I now I'm reviving this topic from several years ago, but I would like to know, if with this barcode scanner you need anything else?
You just scan the barcode and the information goes to excel?
It is a USB right?
Community Member
Barcode Scanners
I am not sure whether this barcode scanner is what you need, but you can have a try, because it is a free trial package.
Community Member
Barcode Scanners
Smartphone with barcode scanner app
Super Bronze
Barcode Scanners
I picked up a high quality (ahem) scanner from ebay for about £7, shipped from Hong Kong to the UK... and it worked fine.
I think the encoding is pretty standard.. at least more 'standard' than H323 or SIP :-)
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
