BARS Backup
CM 4.2.3
Can someone tell me the best way to verify if bars is backing up successfully or if it returned errors?
I am used to going into the bars log file and making sure I see
[10:07:19 PM] BARS Scheduler backup operation returned: Success
[11:00:00 PM] BARS Scheduler hourly tracing, current system time = 11:00:00 PM"
But I have another CM Cluster 4.2.3 that does not show these lines at the end of the log file. Thoughts?
1 REPLY
Silver
Re: BARS Backup
To verify if backup is successful perform the following steps:
Open Restore Wizard from BARS menu, Restore>Restore Wizard.
Select Tape in Step 1.
Go to Step 2 by clicking on Next.
If Step 2 displays the server and the application the backup was successful.
This procedure makes no changes to the system so can be safely used to test the validity of the backup.
208
