12-29-2008 07:11 AM - edited 03-15-2019 03:15 PM
my backup history says the last good backup was on 12-01. when I try to do a manual back up, I receive a message that a backup is currently in progress. I try to cancel it but it doesn't allow me to. it's been processing for about a week now, how can I get it to stop?
Solved! Go to Solution.
12-29-2008 07:48 AM
restart the DRS services, BTW there is no BARS in linux versions. it's DRF
java
if this helps, please rate
12-29-2008 07:21 AM
Try to reset CCM service on Publisher (forexample) or reboot your servers from console.
12-29-2008 07:48 AM
java
10-05-2010 10:31 AM
Yesterday, i had the same issue, then i restarted de DRF Master and local, then the problem was solved.
Does anybody know if it can be a Bug in CCM 7.1 ?
