BARS Installation
microtel
I installed BARS ver 4-0-9 on my Call Manager 4.1(3) publisher and i suprised at the end with this display message:*
The wizard was interrupted before Cisco BARS could be completely installed
and in the other dialog box:
Cisco BARS Install did not complete successfully. Review the file log for more information!!
Any idea for this pb
Thanks for your help
Malek
Zin.Karzazi
Level 5
Level 5
Well first thing to do, assuming you already checked the Compatibility Matrix is to view the Log file: C:\Program Files\Common Files\Cisco\Logs
Hi Zin
the Compatibility Matrix URL is not available:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/ccmcomp.htm
is there an other url
allan.thomas
Level 8
Level 8
First and foremost ensure that you have stopped and disabled the CSA if installed prior to installing the BARS utility. Rather than stopping the service from the sys-tray, actually go into Windows Services and stop the service completely, and then attempt the installation.
Allan.
Hope this helps, please rate this post if you find it helpful.
