BARS INSTALLATIONS
HI
I NEED TO INSTALL A BARS APLICATION IN CALL MANAGER 4.1,
DO YOU KNOW THAT VESION OF BARS I NEED TO INSTALL?
THE INSTALLATIONS OF BARS CAN AFFECT THE CCM SYSTEM ?
SOME ADVICE
THANKS
1 ACCEPTED SOLUTION
Re: BARS INSTALLATIONS
Table 15 Backup and Restore (BARS) for Cisco Unified CM Release 3.x Through Release 4.x
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp44734
you need to reboot the server to finish install, read install instructions
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
108
