BARS is not working
BARS(Backup and Restore Server)is not working,in BARS admin page it says:
"A Backup or restore process is in progress
Please try again after some time"(this state is for past couple of days)
If i RESET, is it BARS will restart the backup imdtly or it will start as per the scheduled time..
Please some one help me out!!
pklos
Level 4
Level 4
You should reset status. Do Backup Now! and check log if everything is ok.
regards,
PK
Thanks for your reply,
After Resetting BARS, still backup is not happenning.
It stops and says " staging the server x.x.x.x.....",
any suggestions...
