Bars Restore
I am running CM version 4.1-3
I am trying to replace hardware and do a BARS restore. I restored the new publiser off line and just connected it to the network (which i have done many times before) but this time I noticed the two subscribers would not sync with the pub, looking in enterprise manager I can see that the subscriptions have not been created and when I try to create them I get an error saying "can not create pull sub to this server"
now when I try another restore it fails and says it can't drop the connection to the CM000X database. Should i not restore off line?
Silver
Re: Bars Restore
Check this link for SQL sub problems... DBL helper is your friend :)
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801e7ddf.shtml
Cheers,
Tim
Re: Bars Restore
in many cases the replication is so messed up you might need to do it manually
Reestablishing a Broken CallManager Cluster SQL Subscription with Cisco CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d11a6.shtml
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
99
