Base OS version for CCM 4.2(3)sr2b
I am planning to install CCM 4.2(3)sr2b on a HP DL380 G4.I have installed OS(Base OS version) version 2000.2.7 and planning to upgrade to 2000.4.4 sr10 or later.Will the CCM 4.2(3)sr2b installation go through smoothly?
I am aware the minimum os requirement is 2000.4.2sr10 or later for CCM 4.2(3)sr2b.
But I have observed earlier in some previous installation, the CCM 4.X does not get installed if the base OS version is below certian version.
What is the base minimum OS version for CCM 4.2(3)sr2b?
KMS
Re: Base OS version for CCM 4.2(3)sr2b
same as it would be for 4.2(3)
No minimum SQL 2k requirement but OS 2000.4.2sr10 is required prior to upgrade.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wpxref1412726
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks for replying.Just to clarify,if I install OS 2000.2.7 and next if I upgrade the OS to 20004.4sr10 and than directly install ccm 4.2(3) the install should go smoothly without any compatibility issues correct?
KMS
yes, you should have no issue as long as you have a higher release.
javalenc
java
VIP Super Bronze
KMS,
Always rememebr to rate useful and helpful posts. I will give javalenc 5 point for you!
Please in the future rate posts....
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
138
