Bash Vulnerability affecting CUCM 7.1.5, Unity connection 7.1.5, UCCX 7.x
My Customer has CUCM 7.1.5, Unity connection 7.1.5 and UCCx 7.x version. Is there a fix for these version ? According to Cisco the fix release are on version 10.5. Does that mean there is no fix for 7.1.5 and that the customer needs to migrate to version 10 to apply the fix. Please advice..
CUCM evaluation for CVE-2014-6271, 2014-7169, 2014-6277 and 2014-6278
Ref: CSCur00930
Known Affected Releases:     (16)
10.0(1.10000.24)
10.5(1.10000.7)
5.0
5.1
6.0
6.1
7.0
7.1
7.1(5)
8.0
8.5(1)
8.6
8.6(2.10000.30)
9.0(1)
9.1(1)
9.1(2)
Known Fixed Releases:          (5)
10.5(1.11900.12)
10.5(1.98000.307)
10.5(1.98000.311)
10.5(1.98000.372)
10.5(1.98000.378)
Cisco Unity Connection evaluation for CVE-2014-6271 and CVE-2014-7169
Ref: CSCur05328
Known Affected Releases:     (1)
9.5(0.9)TT0
Known Fixed Releases:          (1)
10.5(1.11900.13)
 For CUCM: Bug description
For CUCM and Unity Connection bug description has been updated, COP file fixes listed releases. So you can upgrade to any of these releases and then apply COP file.
https://tools.cisco.com/bugsearch/bug/CSCur00930
Unified Communications Manager / CallManager / Cisco Unity Connection Utilities-COP-Files
Further Problem Description:
A COP file,ciscocm.bashupgrade.cop.sgn, has been published to cisco.com that can be used to patch existing systems as indicated below.
In addition to the above mentioned COP file, this fix will be included in future software releases and will be made available for all releases that have not reached End of SW Maintenance Releases Date, including
Release 8.5.1 - first fixed release is TBD
Release 8.6.2 - first fixed release is TBD
Release 9.1.2 - first fixed release is TBD
Release 10.0.1 - first fixed release is TBD
Release 10.5.1 - first fixed release is TBD
The short answer is, no, they
The short answer is, no, they aren't going to provide a fix.  Your customer is running a product that is beyond end of life and there is no support.  This is the risk accepted when you do this.
It can be addressed, but you'll have to upgrade to a supported version to gain access to the patch, or patched upgrade media.
Cliff
391
