Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Basic clarification on QoS (CoS-to-DSCP) vs ToS
Hi there, can you help me clarify this:
Let's say I have a Cisco switch 2960, layer 2 switch.
Then if I need to classify and mark a certain application traffic which is connected to a Cisco 2960 switch, I would need to do cos-to-dscp maps.
The reason I need to do that is because at layer 2, we have a frames which do not have knowledge about ToS (IP precedence and DSCP) fields, correct?
The way I understand is that such cos-to-dscp mark is inserted in the application payload which is encapsulated into the IEEE 802.3 frame, correct?
When such frame is forwarded to a layer 3 device for example (which will then be a packet), it will then use the DSCP value to make decisions on how to prioritize and handle the traffic.
Is the understanding above correct?
508
