basic question about sccp, sip, and h323
Hello everyone,
I'm new to voip. I got a dump a question, does the call manager do protocol conversion between sip and sccp phones? if 2 phones (sccp and sip) register to the cucm, how does the call between the two works? There must be some kind of protocol conversion. Thanks
Also, I got some Tandberg video endpoints that I'd like to register to cucm using h323 and make calls between the three protocols, sccp, sip & h323? Does any one have a procedure to do this? Appreciate any input.
Callmanager has the intelligence to accept signaling from different endpoints using different protocols in a single call and relay the signaling specific to the protocol that a particular endpoint understands. Simply put, for your case of a simple test call between a SIP and SCCP endpoint it will be talking sccp to one phone and sip to another. Once the call is setup it goes out of picture and rTP flows directly between the endpoints.
Manish
Re:basic question about sccp, sip, and h323
Manish,thanks , that's what I thought but just want to double check with experts on here
Re: basic question about sccp, sip, and h323
In terms of registering h323 endpoints, it depends on what endpoints you have, and you might need a gatekeeper/VCS.
check my post on that:
http://ciscoshizzle.blogspot.com.au/2013/10/vcs-architecture-components-call.html
Please remember to rate useful posts, by clicking on the stars below.
129
