Basic question on CUCM LDAP sync
Hi All,
I have a basic question on using LDAP sync please.
Should I have a platform administrator and cisco call manager application user account created on the Active Directory before running LDAP sync?
I am pretty sure that the platform administrator account can not be  deleted; but I am not sure about the account used to login to the CUCM  administrator web pages.
A Lalli-Cafini
1 ACCEPTED SOLUTION
Re: Basic question on CUCM LDAP sync
No. You do not need to create an AD account for these users. The platform account is locally significant to each cluster node. The web admin account is an Application user object. Application users are not affected by ldap sync. Only End User objects are affected.
Note that you will need a user account configured in AD that cucm can use to perform the sync. This account only needs read access.
Hth.
Bill
please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Hth.
Bill
thanks mate
278
