BAT 6.0: Cannot add Remote Destnation Profiles
Instantly receive "Record does not match the file format selected" error.
Insert RDPs in /common/bps/csvfiles/remotedestinationprofiles/insert/insert.txt
Failure Details :
Remote Destination Profile Name Error Code Error Description
5079RDP Record does not match the file format selected.
Result Summary :
INSERT for 0 RDPs passed.
INSERT for 1 RDPs failed.
Insert.txt
REMOTE DESTINATION PROFILE NAME,DESCRIPTION,USER ID,DESK PHONE MAC ADDRESS,PARTITION 1,DIRECTORY NUMBER 1
5079RDP,D-5079,5079,SEP00070E36A0FA,INTERNAL,5079
I have tried to export a manually created RDP into the file and then import it back, but I have received the same error.
Anybody has tried to do the same?
Thanks!
Silver
Re: BAT 6.0: Cannot add Remote Destnation Profiles
You need the "assign file format" to be successful before the actual update will work.
This document expalins the procedure:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/5_0/bulk_adm/5_0_4/t14csvap.htm#wp1232194
Im getting the or similar error with import new users to cucm. Did you find a fix?
Hi all!
I have solved my problem.
When you add RDPs using BAT file with MAC Addresses, then you do not need to select RDP template. Using the template will generate the error.
352
