03-05-2008 02:20 AM - edited 03-15-2019 09:14 AM
I'm having problems associating Users (who are sync'd with AD) with the Associated Device. I've used BAT to update users but it doesn't work now. The file runs in successfully but no changes are made. Any ideas?
Cheers
Rich
03-05-2008 02:41 AM
I've used BAT and AD integration with CUCM 5.1.3 and using BAT for associating phones to users works fine. Maybe you BAT file is corrupted?
regards,
PK
03-05-2008 02:44 AM
Hi PK,
Do you mean the file I created using BAT or the actual BAT template downloaded from CCM? If later,how would I get around that?
Cheers
Rich
03-13-2008 12:03 PM
I had the same isssue. Try this go into the Bat file and changed the "controlled" devices from 0 and 1 and that should do the trick :)
03-16-2008 01:39 PM
Tried that one-thats how to display the Controlled Devices column isn't it. Its weird because I used the same format for a bulk update but it doesn't work now :(
