10-13-2014 01:36 PM - edited 03-17-2019 12:31 AM
i want to configure CUC to send voicemail to email .
So i know i go to the users in Edit>>Edit Message Actions>>Voicemail>>Accept and Relay the Message, Relay Address>>(email of user) .
But how to do this for all users using BAT ?
Best regards,
Guillaume
10-14-2014 08:27 AM
Hi Guillaume,
Rather than BAT, I believe you would need to use "Bulk Edit" for this task;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/user_mac/guide/8xcucmacx/8xcucmac090.html#55802
Cheers!
Rob
10-14-2014 08:43 AM
Think we were posting at the same time there Rob!
Couple of idea's to try Guillaume! :-)
10-14-2014 08:28 AM
Yes you can, have a look here, you just need to build your CSV file and run an 'Update':
Search for 'RelayAddress'
Hope that helps!
Matty
10-14-2014 09:32 AM
Hi Matty,
Good stuff my friend :) +5 for your good thoughts on this.
Cheers!
Rob
