BAT and Cisco Unity Connection
i want to configure CUC to send voicemail to email .
So i know i go to the users in Edit>>Edit Message Actions>>Voicemail>>Accept and Relay the Message,   Relay Address>>(email of user) .
But how to do this for all users using BAT ?
Best regards,
Guillaume
Everyone's tags (1)
Hall of Fame Super Red
Hi Guillaume, Rather than BAT
Hi Guillaume,
Rather than BAT, I believe you would need to use "Bulk Edit" for this task;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/user_mac/guide/8xcucmacx/8xcucmac090.html#55802
Cheers!
Rob
Bronze
Think we were posting at the
Think we were posting at the same time there Rob!
Couple of idea's to try Guillaume! :-)
Bronze
Yes you can, have a look here
Yes you can, have a look here, you just need to build your CSV file and run an 'Update':
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/user_mac/guide/8xcucmacx/8xcucmacappa.pdf
Search for 'RelayAddress'
Hope that helps!
Matty
Hi Matty, Good stuff my
Hi Matty,
Good stuff my friend :) +5 for your good thoughts on this.
Cheers!
Rob
106
