04-20-2009 04:31 AM - edited 03-15-2019 05:32 PM
have cucm version 7.0.2.10000-18.
I have ldap sync with AD.
I've imported phones and have been successfull at getting the association of phones to users to work.
I cannot get the primary extension to update.
I have only one instance of this extension in the system and are using the update users tab on bat sheet.
Also, in creating the user template i specified the subscribe calling search space and this is not updating either.
thoughts?
04-26-2009 04:04 PM
I am having the same problem also on exact same version of CUCM. I am only having the problem with the primary ext field though.
Everything else is ok though, after I BAT'd all of my users/phones I also tried another BAT with just updating the users and no dice!
I think this may be a bug. I do know that thier is an ES8 out for our version of CUCM, but haven't had a chance yet to confirm this with TAC.
04-26-2009 05:03 PM
found the fix.
change primary extn field to text and put in format of "xxxx in
that fixed it for me.
04-27-2009 05:26 AM
Nice! Can you send me an example of what you did?
Thanks.
04-27-2009 07:05 AM
04-27-2009 07:19 AM
So "6320 in DEVICES-P" you placed under the Primary Ext column...so 6320 is someones ext number and DEVICES-P is the partition?
For instance mine would be:
"81522 in Line1-PT"
04-27-2009 07:21 AM
That's it.
Kinda weird but whatever works right?
Hope this works for you.
04-27-2009 07:25 AM
That is weird, the way the db is set up must be incorrect for this table/column, but hey whatever works!
I will try, thanks again!
Cheers.
05-26-2020 11:28 AM
Working in 12.5 and this fixed it!! Complete crap this is still a thing....but thank you to the person who figured this out.
05-26-2020 10:50 PM - edited 05-27-2020 02:56 AM
Maybe I’m daft, but I don’t understand what you all think is wrong or odd with this? The reference for a directory number is “DN in PT”, there is nothing odd about this. The combination of DN and PT is what makes this unique in the system. Technically you can have the same number in multiple PTs, but that doesn’t make it the same DN from the perspective of how CUCM operate.
05-27-2020 01:07 AM
I guess it's slightly strange having two fields DN and Partition concatenated into one CSV field in this way. Looking back at old BAT files it looks like the format changes over the years as well, it used to be entered without spaces for example "2311821inPT-SNY-WS-Internal"
05-03-2013 04:45 AM
I am working in a 9.1 system and had the same issue. This did fix it though. CRAZY
