Community Member
BAT and TAPS for CM6.1 LDAP users
I have a CM6.1 with LDAP authentication for Users.
I already have the users imported in CM. I am trying to use BAT and TAPS to simplify my install but I dont know how to do it with LDAP users.
I am trying to associate phones, extension mobility profiles and DNs associated with LDAP users.
Is is possible, what template to use?
Joel
Hall of Fame Super Silver
Re: BAT and TAPS for CM6.1 LDAP users
You can use the Update Users BAT and specify te controlled device in the file.
Chris
you need to load in the users first into CUCM or make sure they are synced from LDAP. Then use BAT to import the phones or TAP the phones. Then you will have to use BAT to associated the phone to user.
It's kind of a couple step process using BAT as your "vehicle".
168
