Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
BAT (Bulk Admin Tool) & Open office compatibility
Is it possible ? Does it work ? If any of you've had any success running the BAT with OpenOffice, how were you successful ?
1 REPLY
Anonymous
N/A
Re: BAT (Bulk Admin Tool) & Open office compatibility
With Portable OpenOffice you do not have to install anything and can edit your BAT csv files on the server. Just download the zip file, extract it, and run Calc directly from the extracted folder. No install necessary. To properly format csv files for CallManager BAT tool, make sure you clear the quotes from the text delimiter when opening the .csv file.
144
