05-26-2009 02:18 PM - edited 03-18-2019 10:21 AM
Hi try updade lines on CUCM7
On Bulk Administration -> Phones -> Update Lines. I select the lines and select the change (partition), so I click on submit.
But on Job Scheduler, the task show like Pending, I activated the job, delete, re-created and nothing. This same thing with update Phones.
Is there any service that must be activate?
Peterson
Solved! Go to Solution.
05-27-2009 06:04 AM
Make sure the Cisco Bulk Provisioning Service is running
java
if this helps, please rate
05-27-2009 06:04 AM
java
06-24-2009 05:56 AM
Hello Java,
I am trying to activate de Service, but when the page reloads the service still deactivated.
you know what can be? I am runing ccm 5.1(3)-1000
09-03-2010 09:18 AM
I was having the same problem of it not getting past "Pending". Tried deleting the job,
re-adding. Stop Processing, then Start Processing. Activate Selected Job. Made sure the necessary services were activated, namely BPS, but also AXL and TAPS (as suggested by Cisco help site). Finally, what worked was deactivating the BPS service, save, then reactivating it, save
