Community Member
BAT Export External Phone number mask
I am trying to run BAT to export the DN and the External Phone number mask so I can see if any of my phones are missing the External phone number mask. Does anyone know how to filter it down?
Bronze
Re: BAT Export External Phone number mask
Use the export All Details option and then save the file as csv and open it with excel.
//Jorge
Community Member
Which is what i have done for a similar issue.
The problem now is that, it isn't that easy to locate the correct column for this field.
Does anybody know how to get the relevant headings into Excel to marry up with the imported text file???
384
