Bronze
BAT Export template customization in Cisco CCM 4.x?
Hi all,
Happy new year - 2012
Can we customize the phone export template? There are 2 options now: Default and All phone details. Default template is not giving parition and calling search space whereas All phone details template is so exhaustive.
Basicallly, I just need MAC, Line DN, User name, Parition and CSS as part of migration to Cisco CUCM 8.x.
Regards...
-Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
Hall of Fame Super Red
Hi Ashok,
Happy 2012 to you too my friend
Sadly the Export function is not customizable;
Step 4 In the File Format Name field, choose either the Default Phone or All Phone Details file format. Your choice determines the export option and sets the appropriate export option radio button.
For All Phone Details file format, choose the type of device or specific model in the Model list box under the All Details radio button. See Table 10-1 for the list of exported fields in this format. Skip to Step 6.
For Default Phone file format, choose the type of device or specific model in the Model list box under the Specific Details radio button. See Table 10-2 for the list of exported fields in the default phone format.
Step 5 You can customize the export file by choosing which set of phones to export, but the phone details are not configurable. Choose from the following fields:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/5_2_3/bat_exp.html#wp1086410
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
Super Bronze
You can just open it in a spreadsheet app and take out the columns you need.
If you are running into the 'too many columns' error in your version of Excel, try downloading openoffice as that seems to work better for me.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
307
